shower steamer
Re: shower steamer
I'd start with the steamer's instructions.
[ December 17, 2005, 03:09 PM: Message edited by: LarryFine ]
Re: shower steamer
A shower steamer in usually located in a different location or compartment other than shower and hopefully metal water piping (if used)is bonded or piping is poly. The steamer unit is grounded at a terminal within unit. No electrical continuity to user and ground fault protection is not required.
Re: shower steamer
I've never installed one that had such a requirement. They generally run in the 50-60 amp range. Think of them more like a water heater, which doesn't require GFCI protection either.
Re: shower steamer
Yeah it is like the a water heater. Just wanted to be sure. Thanks
Re: shower steamer
Just did one.
50amp.
No GFCI.
Cat5e was run by 'others' from shower to unit for control.
Thought they were saucy and had a web cam going in. :D
