shunt disco very long path... network signal to trigger... or dry contact only?
wyreman
SF CA USA
I have to run 400' over hill and dale - transitioning levels and materials to get to a very old fpe qmqb 100a 3phase disco
I am looking for alternative methods.
I have been running some very useful network control of HVAC systems lately with network control picking GErr7's
really pretty robust - sometimes there is a little network lag, that's about it
In this case this is an existing structure that has just got a State Inspector call for a disconnect within sight.
The machine has a local shutdown control but no local disconnect of all conductors coming out to the unit.
Like me,,, It's pretty old =0
hihi
That's all fine
Low voltage shunt wire may be what I run.
I'm looking for feedback on alternate ways to intercept those power wires way over there without [my son] crawling 200' in the mud then coming up and running emt on concrete, boring and coring all the way.
Network picking GE RR7 looks appealing.
Forget about using RF!!
I may just use some dry contacts and skinny Cu anyway because I really don't ever want to have that thing shunt when it's not supposed to or,,, the other way around !
thanks Guys
Hello,
How far apart are those setups? What voltage are they?
Pjholguin
hihi
That's all fine
thanks Guys
wyreman
SF CA USA
Looks like 200 linear feet and almost 400 foot of wire from the point of use to the source.
It's 240v 3phase 100a
Thx
In belief, man can do anything
wyreman
SF CA USA
Update : insp may be ok with a much shorter run from operator to unit in which case the job is straightforward thx !
