shutting down the entire kitchen seems like a good idea and isnt much harder than shutting down the gas valve and outlets under the hood. simplex is pretty good at explaining things to you. the guys i worked with were pretty smart about the system and didnt mind to take the time to explain itquogueelectric said:Lately the most recent jobs I have done including these setups, shut down the main for the entire kitchen panels thereby shutting down all cooking equipment in the kitchen which could be causing the fire. For example if an electric deepfryer caught fire and tripped the ansul system it would trip the kitchen panel which was feeding the power to the fryolator to help extinguish the source of heat while the ansul was working to put out the grease fire. There are numerous other fire code related functions which you should not be getting involved in unless you are qualified or instructed by a licensed fire system installer/designer such as Simplex/Pyrotronics and there are others.
When you do the job right it gets very expensive very quickly and there are heartless contractors out there who dont understand the legal process and why it is in force is because other people lost thier lives in a fire because of this. Safety is important and just like you put your life in the pilots hands when you board a plane you would like to know the electrician is competant to be doing your work.electricalperson said:shutting down the entire kitchen seems like a good idea and isnt much harder than shutting down the gas valve and outlets under the hood. simplex is pretty good at explaining things to you. the guys i worked with were pretty smart about the system and didnt mind to take the time to explain it
That's a good idea, and I've re-used existing shunt-trip mains. The one problem with that is that the exhaust fan(s) and horn-strobe must receive power after a trip, meaning they require another source of power.quogueelectric said:Lately the most recent jobs I have done including these setups, shut down the main for the entire kitchen panels thereby shutting down all cooking equipment in the kitchen which could be causing the fire.
