I am involved with a project that has multiple main disconnect switches grouped outside of a single story building. Three of the switches are fusible disconnects and the fourth is a shunt trip pushbutton that operates a mian circuit breaker in a panel within the building. Service disconnecting was designed this way due to space constraints. I have argued back and forth with the local inpector that the shunt trip pushbutton is a recognized means of disconnect and is stated as such in NEC 230-76(2). My inspector's arguement is that it is not considered a means of disconnect and is stated as such in NEC 230-71. I have tried explaining to him that the purpose of 230-71 is to limit the maximum number of disconnects and that a shunt trip pushbutton does not count against the maximum number. It's intent is not to recognize the shunt trip as ameans of disconnect. He states that a shunt trip pushbutton is acceptable only if the breaker handle is next to the shunt trip. Can anyone out there set me straight on this?
