roger said:Basically it means to provide a parallel path of lower resistance into a circuit. The lower resistance path will shift/shunt the current flow from another path.
Roger
As roger said, "Shunt" means parallel, but not in the usual sense. The OC trip element sensors are in the line main current flow path - "series" one might say. The shunt trip element is a "parallel trip element" to the OC trip element - mechanically parallel. A shunt trip on a CB has an actuation coil, takes 24 - 120 AC/or DC to activate.Jakewhis said:Could someone help me make since of this word. I've heard the term shunt trip breaker. I've heard people say that devise has been shunted. What is a shunt.
Jakewhis said:I've heard the term shunt trip breaker. ... What is a shunt.
How did I do Augie??augie47 said:all the definitions were wonderful.... now, how does that explain a "shunt" trip breaker
Right. The meter I typically used for that came with stickers to make it whatever kind of meter I wanted it to represent itself as. I liked the simpson Hawk meter for that.don_resqcapt19 said:Marc,
That shunt is huge (of course plating currents are very high), but I have seen much smaller ones in DC drives and things like that. However I don't think you connect an ammeter to the screws....I believe it would be a millivolt meter with a meter face labeled in amps. You are really measuring the voltage drop across an know resistance.
Interesting comment. I've never seen any specs on the frequency response of a current shunt. Is this common for your work?langjahr@comcast.net said:Plus the freq. response is almost unlimited, unlike a clamp-on ammeter. ...
Hey,Jakewhis said:Could someone help me make since of this word. I've heard the term shunt trip breaker. I've heard people say that devise has been shunted. What is a shunt.
Shunt coils only come in 24 to 120 volts?coulter said:As roger said, "Shunt" means parallel, but not in the usual sense. The OC trip element sensors are in the line main current flow path - "series" one might say. The shunt trip element is a "parallel trip element" to the OC trip element - mechanically parallel. A shunt trip on a CB has an actuation coil, takes 24 - 120 AC/or DC to activate.
Different use of the work "shunt" for "shunt field" or "shunting a device"
carl
quogueelectric said:How did I do Augie??
