M4gery
I have a bit of an odd situation. A customer wants a spot light mounted up high in a surface mounted box with a PVC pipe running down to a switchbox, the feed will be coming in from the back of the switchbox. It's in his backyard so he doesn't mind the surface mounted devices (not the way I'd normally do it). Both the light box and the switch box will be mounted to the siding.
My options are to:
A) Mount the boxes directly the the siding even though they won't be plumb.
B) Mount the boxes to the siding but shim them out somehow so they are plumb.
C) Find a pair of siding blocks made for both the round box and rectangular box to be surface mounted to. Most siding blocks seem to be for recessed boxes so I wouldn't be able to run the conduit between them.
Mind you, this is an estimate and I'm competing against others who might take the easier way out, the customer doesn't seem to be too picky since it's not in a place that will be seem much. What would you do?
My options are to:
