goldstar
- New Jersey
- Electrical Contractor
I recently did some work for a friend that was having his entire house remodeled. One of the jobs he had done was new vinyl siding. I met with the GC and removed all conduits on the outside of the house. In addition I also removed the meter enclosure and provided an Arlington back-plate, and I install (3) Arlington DBVS1C "in use" receptacle enclosures with new GFI receptacles in each. I cut the holes into the original siding and left them hanging loose so that they could install the foam insulation and Tyvec wrap and then nail them on by the flanges. What a real nice guy I was.
I went back to the job a month later to do some additional work on the inside and found that the meter enclosure was installed on the vinyl siding with no back plate, the GFI 'in use" boxes were discarded and the GFI receptacles installed with a std. indoor trim plate screwed into the siding with sheetrock screws and back boxes behind them.
GFI code violation
I wrote a letter to the building dept and advised the electrical inspector that there was unauthorized electrical work done on this job and advised him of the code violations. He showed up on the job, passed the interior work but failed the exterior. Is there anything else that any of you would do in this situation to protect yourself ?
GFI code violation
