are pressure plate ul listed for that use ?????????????????????I don't think Siemens breakers are. But basically, if they have a pressure plate instead of just a screw, then two wires can be used.
Not sure about exclusively saying pressure plates being listed but breakers (such as square D) list the breakers as allowing two conductors.are pressure plate ul listed for that use ?????????????????????
Not pretty, but a wire nut is legal if it isn’t.IS a Seimens 20 amp breaker type qp rated for two wires under its lug ??????????????????????????????????????????????????????????????????????
no. Some Square D breakers are. If they are it will say so right on the breakerIS a Seimens 20 amp breaker type qp rated for two wires under its lug ??????????????????????????????????????????????????????????????????????
