Hey guys
I'm new to the forums. I would appreciate any help with this problem. I installed one 15 amp Siemens Arc Fault overcurrent protection for a single branch circuit to feed 7 recessed lights with 65 watt bulbs. I also install one 220 volt dedicated 20 amp branch circuit for a baseboard heater with a 2 pole t-stat on unit with a normal non Arc Fault overcurrent protection. I put the lights on and the breaker holds all day, while the lights are on i turn the t-stat on from the heat and the breaker trips instantly. Could that be Harmonics? The 220 line has no neutral. It is a single phase home 120/240 coming in from the primary. The 15 amp Arc Fault overcurrent is on phase A odd side, the 220 volt non Arc is on even side of B-A. I don't really have any troubleshooting time on these breakers yet. New Jersey adopted it from the NEC to the UCC for a couple of months. Now there not using them, but i installed them in the time we were required to. Any help would be appreciative.
Thanks
Vinnie
Thanks
Vinnie
