No, they are only listed for 240 volt use.
So what do all the apartments that are fed with 3 phases Y services do for afci protectionNo, they are only listed for 240 volt use.
208/120 is what voltage across 2 phases?Did you miss that this is a 2 pole breaker? :huh:
Do you have specs on the Siemens that I can look at? I called tech support a few years ago with Sq. D and they told me and sent information saying Sq. D would not work on 208 volts.
Product literature shows it for use with 120/240 volt panels only.
http://w3.usa.siemens.com/us/intern...docs_AFIC Circuit Protection/MY_DS_CAFCI2.pdf
Thanks for the information I appreciate it.:thumbsup:
Yes so why did you say they were dp breakers. Someone can wire an apt with multiwire branch circuit and be stuck with needing dp breakers. I was surprised that if you wanted to add afci on an existing multiwire branch circuit that you could not do it in apts feed with 208VIs this a trick question? :? It's 208.
Surely you're not suggesting that single-phase line-line loads are never installed on three phase systems.
Because the double pole AFCI is limited to 120/240 volt circuits. We're arguing the same thing.
I think Dennis' question is still unanswered though. If you're required to have AFCI breaker on a 2-pole circuit and the panel happens to be 208V, are you SOL if you didn't think to install a GE panel (per bsmith8691)?
If you are adding a new circuit you obviously would not use a multiwire branch circuit and if you are extending the circuit then use an afci Receptacle. Probably not a problem.I think Dennis' question is still unanswered though. If you're required to have AFCI breaker on a 2-pole circuit and the panel happens to be 208V, are you SOL if you didn't think to install a GE panel (per bsmith8691)?
The only manufacturer that gives you a way out on a 120/208 panel that has MWBCs in it is G.E. and their Mod 3 breaker. You use two single pole breakers with their handle tie. Wire it to their spec, it is U. L. listed for that use.
Sent from my XT1254 using Tapatalk
