Rem1061
- Baytown TX
- Senior I&E Maintenance Technican
Hi Folks,
I am (I thought) fairly good with VFD's but have run into an issue I cannot resolve.
We have a large number of both large and small Siemens VFD's in a fairly new unit, and the small ones keep tripping when our main PF cap banks switch.
As this is a bit annoying, we are installing LINE (not load) reactors. Issue is on one of these units, which normally runs fine, when we install the line reactor it will instantly trip on DC Bus overvoltage every time. Within 1/2 a second. The drive hasn't even begun to increase it's output from 0Hz. Without the line reactor, runs great. Add it and instant trip. Tried the same reactor on a different drive and everything was fine. Tried hooking up a same size (1 hp) motor directly at the drive and it runs just fine with the reactor. I could maybe see reflection on a long lead length, except we are talking about a LINE reactor, and we don't have any problems with DC over voltage until we install the reactor. Any ideas?
Thanks
Thanks
