davidbananas999
- Minnesota
So I am taking my journeymens test in 6 days! I can not for the life of me get these terms straight in my head. I feel like they're all the same things, but each has a different name depending on where it's installed.
One thing I do understand is the service neutral and whatever grounding thingy can only be connected (bonded?) in 1 spot otherwise you can get objectional currents on wires running in parallel. Or something like that.
PLEASE clearly explain each of these terms, and provide a straight-forward example of where each is used:
Bonus questions:
Where are bonding bushings required?
What are the benefits or requirements for installing the grounding thingy outside of FMC?
Do I need to connect the grounding terminal for switches, receptacles, or gfci receptacles to a surface-mounted 4-square box, using a raised exposed work cover,
if the box is installed with EMT all the way back to the panel?
THANK YOU SO MUCH!
- equipment grounding conductor
- grounding electrode conductor
- system bonding jumper
- supply side bonding jumper
- main bonding jumper
Bonus questions:
THANK YOU SO MUCH!
