In a class1 division2 environment:
1)What type of cable should be used for wiring to devices such as pressure transmitters (4-20mA) and RTD's? All components are located within the C1D2 environment.
2)If Ethernet wiring is ran in rigid conduit to a NEMA 4X enclosure and passes through a sealoff as it enters the non-hazardous area, does the outer covering have to be removed at the sealoff or is special wire available?
