Bob Kraemer
- Ohio
A friend of mine is a GC located in Cincinnati, Ohio and does work out of town also.
This project is located in Akron, Ohio. The sign contractor has driven a metal pole in the ground about 7ft deep to attach the sign to. The electrical contractor ran PVC under ground to the pole attached a W/P box for the electrical connections. The final inspections were yesterday and the electrical inspector turned the job down because 1) there wasn't an access cover on the pole itself for the electric connections "The box was weather proof and did have a proper cover on it" 2) There wasn't a ground rod driven for the pole. I don't have a copy of the 2005 NEC handy to look it up for him & the inspector didn't give any article numbers for failing the inspection for reference like 600-7.
What is you opinion on this?
Thanks
Bob Kraemer
RK Electric
Thanks
Bob Kraemer
RK Electric
