jwnagy
- Damascus, Maryland
I was going to use this to explain how a capacitor works with alternating current:
Q: Why is direct current blocked in a capacitor and alternating current is allowed to flow?
A: "Because AC is cycling on and off. This means that the electrons in the electrical field between the plates is constantly having voltaic pressure applied to them, first in one direction, then in the other. Every half-cycle the current turns off, the capacitor discharges, and the field begins to charge again, with current flow in the opposite direction.
We can liken this to a pipe filled with water, having a membrane (Dielectric) separating the interior into two halves (plates). Both sides of the pipe have the same initial pressure (potential) applied against both sides of the membrane. Applying more pressure one side forces the membrane to flex and exert pressure on the water on the other side of the pipe. Release the extra pressure and the pressure against the membrane equalizes (field discharges). Applying extra pressure in the opposite direction now moves the membrane in the opposite direction and water on that side of the membrane is moved in that direction. Water is moved on each side of the pipe without the water in the pipe ever crossing the membrane or coming into direct contact."
Does this strike as a simple explanation? Is it correct? :?
Jeff
Jeff
