scott thompson
- Anaheim, California
Got a simple question regarding the use of LFMC for the Raceway of a Grounding Electrode Conductor - either in a small "whip" form (small 12" length, connected to something like EMT), or a continuous length.
Was asked this by a colleague recently, and wanted to toss your way!
Say, for example, we have a Dry-Type Transformer, and we are bonding the Secondary side of it to a local Grounding Electrode System via a Grounding Electrode Conductor (sized per 250.66).
In an attempt to reduce the 60 Hz vibrating hum, all Conduits terminating to the Transformer's Enclosure have 12" long whips of LFMC (Metallic Sealtite) between the EMT and the Transformer's Enclosure.
Bonding Bushings are used on both ends of the GEC's raceway.
If I am reading 250.64 (B) correctly, the Article _Does Not_ include LFMC as an optional raceway for the GEC to be run in.
The Article includes GRC (Rigid Metal Conduit), IMC, EMT, PVC (Rigid Nonmetallic Conduit), or Armored Cable - but does not include LFMC or LFNC.
Is this a simple "forgot to include LFMC in the list" thing, or is it due to the "typical Ground Bonding Limitations" printed on the LFMC.
Example:
1/2" LFMC normally has printed on exterior: "Use Separate Grounding Conductor for Circuits Above 20 Amps"
Any thoughts???
Scott
Example:
Any thoughts???
Scott
