hardworkingstiff
- Wilmington, NC
I was at a facility today that had a 3 HP pump feeding (water) to a 1,000-gallon pressure rated tank. They had a small air pump keeping pressure in the tank, but it had a low CFM rating. Theory being when the water was high in the tank it would keep enough pressure in the tank during small demand periods that will keep the submerged pump from cycling on/off too much.
I questioned the design and they admitted they were having some "tweaking" problems.
Seems like they need a very simple PLC with a pressure transducer for water height and one for air pressure in the ullage space. Write the correct logic and you have a nice control system that is easy to modify after usage experience.
Does anyone know of a product like what I think I'm describing?
Thanks,
Thanks,
