Supposed the ground rods at the utility pole and your main panel get disconnected lets say from seismic activity or roads works, etc. So the North American centertap transformer neutral is connected directly to your washing machine metal enclosure, and then you touch the metal enclosure and your bare feet touches the floor. Would you get a shock?
Or to make it simple. What would happen if the utility pole centertap neutral lost all its grounding, and you touch the hanging neutral with one hand and the other hand touching the disconnected ground rod. Would you get a shock?
Or since the transformer is an isolation transformer, then when the secondary lost connection with the ground. It becomes floating and just like the small isolation transformer you use at work bench to avoid connection with ground where you touch live and ground and not getting a shock. Then nothing would happen to you if the same thing happens to the utility pole case?
Of course I won't do it intentionally. Just what would happen and the principles involved. Thanks.
