comjos
- Pikeville KY
I have a question that I should know but here goes. In completing the Standard Service Calculation the Demand Load was 230 amps the Minimum Service Required is 250 amps. According to the NEC with the main disconnect within an enclosure to be derated at 80%. Should the main be (1.25% x 250 = 310) or next higher 350 ampere OCPD? I get a little confused in terms of the Service Calculations and the main disconnect.
