Could someone direct me to the NEC Article that addresses a Grounding Conductor run in a single raceway with two circuits? In this case I have two 120V 20Amp circuits running in a single conduit; at the end of the run are two Outlets (one for each circuit). I?ve sized the grounding conductor on total ampacity of the two parallel circuits. I believe it?s permissible to run a single ground for two circuits this way and remember having read about this in the NEC.
