Where only one grounding electrode is used.
250.52 lists the electrodes permitted for grounding. I have noticed that some inspectors are saying that the electrician has to use a concrete encased electrode.
1. They site 250.50. Doesn't that only pertain to to bonding where there is more than one grounding electrode?
2. If a concrete encased electrode is require to be used in all cases where it possible to install one why is it just listed with the other grounding electrodes permitted in 250.52?
250.30(A)(7) states that you must use a water pipe or structural metal but if they aren't there you can use one of the others.
3. Why doesn't the code state that a concrete encased electode is required and if not possible you can use the others that are permitted?
4. If all of the different types of grounding electrodes are acceptable why can't the electrician decide which one they use?
It is clear as mud but it covers the ground and the confusion make my head go round.
Hope this isn't too much for my first post and question.
Thanks for your help in advance.
