AngryElectrician
New member
- NJ
I'm hoping someone can point me to the code rule that covers my question and settle a disagreement. In the midst of building a machine control panel, a co-worker used a standard Romex or NM cable connector to hold 4, single, #12 AWM conductors to pass through the steel panel on which all of the control equipment is mounted. From there, the conductors connect to 400V (for an overseas project) for power to the unit. I have always understood this to be a code violation, but I am unable to find the rule that applies. My understanding is that such a connector should only be used with a fully sheathed cable assembly, like a standard Romex cable. Even in the case of say, installing a Romex cable into a metal box using a standard connector, a portion of the sheath must pass through to the other side of the connector to comply with code to help prevent wire abrasion. Can anyone point me to the code rule and confirm my suspicion? Thanks.
