Can two transformers, installed in parallel and fed by dedicated conductors, be protected but a single primary breaker? Client has a 33kv/65A breaker that feeds a 3.75mva 33kv/480v wye transformer. They current 3.75MVA transformer only operates at only about half its rated load and therefore they want to feed a new 1.5MVA transformer, elsewhere in the facility. This new 1.5mva transformer would be fed by a new dedicated feeder that terminates on the load side of the existing 33kv/65A breaker. This is not for life safety equipment and the client is aware the problems caused by this non-isolation scenario. Thank-you
