27hillcrest
Do they make a such a thing. I need one to control a 1/3hp motor for a steam kettle in a kitchen.
TIA
TIA
TIA
TIA
There is a low water cut off that should be turning on and of the 1/3hp motor. In the directions for the low water cut off they said the contacts are not rated for the 1/3 pump. So they recommend isntalling a starter. Any Thoughts
A RIB is the easiest install.
Yes. See: RIBsPlease explain RIB (Relay in a Box)??
