kgregg
- baltimore, md
I was wondering if there are any code issues with having a single panel feeding several units in a multifamily (3 unit) building. The panel will be located in the common area. Building owner will be paying the electric bill.
There are two meters to the building, a 150A service to the basement unit and a 200A service to the upper 3 units. There will be a sub-panel from the basement unit that will be on the upper floor serving the condensing units on the roof. The basement units panel will be within the basement unit, not common area.
This is far from what im use to and the owner is trying to cut costs...is this configuration possible?
Thank you.
Thank you.
