- Chapel Hill, NC
- Retired Electrical Contractor
If single phase does not consist of 2 phases and 3 phase consists of 3 phases why is a 208V pump connected to 2 phases of a 3 phase system considered single phase?
Are you a newbie here? This gets asked a lot.If single phase does not consist of 2 phases and 3 phase consists of 3 phases why is a 208V pump connected to 2 phases of a 3 phase system considered single phase?
A old 2Ø system has the phases 90° apart. That's nothing like our modern 3Ø systems.
I know and I think they know that yet they want to call it 2 phase
Walking my big handsome collie - where else?where's Besoeker ?
I think he has worked out that I have problems with my vision and sticks close to me. My minder.
And I think the single phase, two phase discussion has been done to death.
Two hots 180 deg apart.........
OK.It is really not about single phase 180° apart. It is about the 3 phase and using 2 phases for the pump and being called single phase.
OK.
But he really is a handsome beast with such a lovely temperament.
Because there is only one sine wave across the load.If single phase does not consist of 2 phases and 3 phase consists of 3 phases why is a 208V pump connected to 2 phases of a 3 phase system considered single phase?
A two terminal device is a single phase load no matter what it is connected to. In the broad sense this goes all the way down to zero frequency, DC.
This.
We can argue _forever_ about one versus two phase with systems that have a 180 degree phase difference (or an apparent 180 degree phase difference depending on where you stand in the debate). But the question of a 2 terminal device is separate.
With two terminals you only have a _single_ circuit with a single electrical phase angle.
It doesn't matter what the 'phase to neutral' phase angles of the supply system are, or how many different phases there are in the supply system. That 208V could come from a 240:208V single phase transformer, or it could come off of two separate phases from a 208/120V wye system, or it could come from a single leg of a 360208V wye system, or it could come from two separate phases of a '2 phase 5 wire' system with 147V line to neutral. All the load cares about is the voltage between the two connected terminals.
So it is perfectly reasonable to say that you have a single phase load connected to two phases of a three phase system
-Jon
