leeman48183
- Electro tech Utilities
Hello
I have 3 hots and a neutral. Sized correctly. 2 black hots going to a double pole 30A breaker. AC unit. Same conduit. 1 red going to a separate 20a circuit breaker. 1 neutral going to neutral bar. So, the question is. Is this wrong? Should I do something about this. This building is 40 years old. I just bought it. I know the 2 black wires on the 30A double pole breaker will cancel neutral return current out. So, the 20a Red is the extra circuit that will be the difference on the neutral. 1 leg of the black and the red are on the same phase.
Will not be able to shut off both breakers with 1 action.
PLEASE HELP ASAP and thanks to all for what you have done and will do in the future.
DP
DP
