ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Understand that the labeling says what the equipment is rated for, not what the service actually is. For example, I got burned early on in my experience when I read the rating on a main MDP switch that said 480V when the service was actually 208V. From the switch labeling I thought it was a 480V service and I designed a system accordingly. I fixed it but it was an expensive learning experience.Main says
"240/120V, 3phase 4 wire Delta"
"208Y/120V, 3ph4wire"
400A rated service.
What doesn't kill you makes you stronger.
