HVAC Guy
- United States
Data plate info on a particular motor shows 208/230 volts, 1.2 FLA. As I understand things, a ?10% variation in voltage is allowed, so the acceptable operating range of voltage could be anywhere from 188-253V. I know, generally speaking, at a particular load, the current draw will increase with a decrease in applied voltage, to maintain the power (P=VI). Based on the same reasoning, increases in voltage would lower the amp draw...
I read somewhere else, "over voltage" on a motor can/will produce a higher current, due to "magnetic saturation" (yeah, sure :huh
, and it seemed to suggest the amount of over-voltage could be within the +10% margin...
That's the question: if the motor is actually operating on a (measured) 251V 1? supply, will it pull more or less than the "rated" FLA?
Thanks in advance...
