So heres what Im reading in this book
"A split-phase motor is a single-phase AC motor that includes a run winding and a resistive start winding that creates a phase-shift for starting. The two windings are placed in the stator slots and spaced 90 degrees apart...... In addition, a centrifugal switch is located inside the motor. The centrifugal switch is used to disconnect the start winding as the motor approaches full-load speed."
So heres my question, if the start winding is in the stator, how is the centrifugal switch, located on the rotor shaft, used to disconnect it.? The start winding gets its power from an exterior source and it is located in the stator, so does that circuit enter the rotor thru slip rings, go thru the centrifugal switch, and then re-exit the rotor to finally be in series with the stator start winding.? That cant possibly be true but Im stumped to envision what the actual configuration is.
