400V and 50Hz certainly exists in the world. The question is hypothetical to an extent. My problem in understanding is just what does the 50/60Hz mean on a single phase motor? Does it mean that the PSC's capacitor is sized to handle the drop to 50Hz? I know that when wanting to adjust the speed of a single phase motor, you adjust the voltage. Bardac makes (or sells) a VFD that will work for single phase motors, but it is far less common than for 3 phase motors. So if a motor that is rated at 460V and 50/60Hz operation is ran on a supply of 400V and 50Hz, the phase shift and the capacitor will be fine but it will just turn faster. As far as I know most single phase motors for fan applications are VT, so does lowering the voltage lower the torque at a cubed rate instead of linear? What exactly happens to a single phase motor when you lower the voltage? What adjustments do manufacturers make to classify it at 50/60Hz? Why are VFD's so rare for 1phase motors (PSC's and Shaded Pole, I understand why you do not want to drop frequency on single phase motors where the start/run caps are more important) than for 3 phase motors? Thanks in advance again. This forum is a great resource for people who take pride in their work. Thank you.
