Leo1
- Los Alamos, NM
Is it acceptable with the NEC to have a single phase, 120/240VAC, 400 AMP main residential disconnect switch (located on outside of house with CTs & meter adjacent) feed a 400 AMP three phase panel-board on the inside of the home? The 400 AMP main disconnect it feed with a parallel run of #3/0 CU to each phase A and B (yes, same for neutral). At the 400 AMP 3-phase panel-board phase A is feed by one #3/0 CU from phase A of the 400 AMP main disconnect. The other #3/0 CU in the phase A of the 400 AMP main disconnect feeds phase B of the 400 AMP 3-phase panel-board. And last the 2-#3/0 CUs from phase B the 400 AMP main disconnect feeds phase C of the 400 AMP 3-phase panel-board.
I do not know why someone would do this unless the 400 AMP 3-phase panel-board was left over from another job and the contractor offered the home owner a discount for the 3-phase panel-board versus buying a new single phase panel-board?
