Hello everyone. Im working at a DoD base in Greenland, and have some questions. They have a 4160V Power Plant that feeds the whole base. There is a remote area of the base (12 miles away) that is fed from the same power plant. They step the 4160v feeder to 69 kv. After the 69 kv Distribution XFMR, it goes through a Air Brake switch, then goes to 3 Single Phase Shunt Reactors. Then out of the reactors to 69kv underground cable, then at the other end, back into the other Distribution XFMR (69kv-4160V) and then into the Medium Voltage switchgear.
I guess I have a few questions. These reactors are loud. I mean a grunting loud. I was curious if this was normal. With an infrared camera, we saw temperatures of upwards of 150 degrees, but the cooling fins seemed to be working properly. We are currently waiting the results of an oil test to determine its di-electric strength.
My next question....What is the purpose of the reactors. I have read that a HV Distribution cable with a small load can produce a significant amount of capacitance. In our case, I wouldn't think our distance, nor the Voltage was high enough to cause this. The feeder circuit has a very small load, btw.
Any help or answers with this would be appreciated.
