I have - 7000kva transformers 208v single phase step down to 42v single phase for a heater. no neutral.
on the secondary side is 167 amps with #2 high temp srml wire and #4 for the ground.
WHAT DO I NEED TO DO FOR PROPER GROUNDING if the primary is feed from a 2pole 50amp breaker indoors then ran thru a SCR.
DO i need to upsize the primary ground to handle the secondary.
