wwhitney
- Berkeley, CA
- Retired
A followup to https://xenforo.mikeholt.com/threads/transformer-basic-physics-question.2569242/#post-2771964 which was too wordy.
My understanding: if you energize an idealized single phase transformer with an open circuit on the secondary, you get the transformed voltage on the secondary, in phase with primary voltage. The only current flowing on the primary is the magnetizing current, and it lags the primary voltage by 90 degrees, like any inductor. Correct?
So now if you add a load on the secondary side, what happens, including to the magnetic flux? I understand the secondary circuit can treat the secondary coil as just a voltage source, and you can find the secondary current accordingly. How does that secondary current change the magnetic flux (if it does) and cause the corresponding transformed current on the primary? That transformed current just adds to the magnetizing current?
Thanks,
Wayne
Thanks,
Wayne
