single-phase?
single-phase?
  • Total voters
    53
  • Poll closed .
I want to answer 'both' :)
It _is_ a 'single phase service' by the definition of a single phase _service_.
But it is not true single phase power being delivered to that service.
-Jon
Can I directly run three phase equipment from this service?
No, because it is a single phase service supplied from a three phase source.
In other words I agree with Winnie and really wonder what all the hubbub is about.
To try to call it a three phase 'service' is IMHO ridiculous.
I like jon's, zog's, bob's answers - all good
IEEE 141 refers to NEMA C84.1, which calls it a "208/120 open Wye". I didn't see anything in IEEE 100.
carl
With only two ungrounded conductors and the neutral of a 208Y/120 3phase 4wire system, we can take two single phase transformers and create three phase.
The IEEE may call this single phase (and I don't neccesarily disagree with them). But, with single phase 240/120 3 wire, the neutral only carries the unbalanced load and doesn't have to be counted as a current-carrying conductor. This is not true of the 208/120 system with 2 ungrounded conductors and a grounded conductor. The grounded conductor has to be counted as a current carrying conductor because the loads do not balance.
-Jon
Winnie, why don't we just use the terminology that EEI uses for metering and call a 120/240 a single phase service and a 120/208 a network service?
[edit: Marc, you just did beat me to the finish line]
iwire said:
IMHO you did.
I guess you could look at it this way, but.....
A building contains walls, floors, roof, etc. Would you call the walls and floors a building (leaving the roof out)?
I did not mean to say that 2-phases of a 3-phase system would constitute a 3-phase system, nor do I believe I said that (I think it's what you expected I would say).
I also do not believe it is a single-phase system although it is allowed to serve single-phase loads.
I now believe this is a topic that will never have consensus and I intend to leave it alone (I hope, I have said this before, lol).
Yep. The power company does it all the time, and calls the secondary an open Delta.
Then the question is whether neutral cancellation is a characteristic of single phase. I say not.
After all, what do we call it when a 3-phase motor loses a phase?
I'm not sure about the the single/dual phase argument but I do know that all the 208 I've ever seen came from Y-connected three phase transformers. The 208 is the phase to phase voltage. 117 is the phase to ground/ center tap of the transformer. (117 x sq. rt of 3=208)
