electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Single phase L-L motor. Can I control it with a single pole switch if the switch is not the disconnecting means?
Yes and the switch should be rated for the line-to-line voltage it will be interrupting.Single phase L-L motor. Can I control it with a single pole switch if the switch is not the disconnecting means?
That's what I thought, but figured there could be something in the dark depths of 430 prohibiting it ( like there is in 410 prohibiting single pole switching of electric discharge lamps).Yes and the switch should be rated for the line-to-line voltage it will be interrupting.
Actually it is the opposite. See 430.84.That's what I thought, but figured there could be something in the dark depths of 430 prohibiting it ( like there is in 410 prohibiting single pole switching of electric discharge lamps).
