codewarrior321
Has anybody here ever worked with SIP Panels On the exterior walls?
What type of method have you used to feed the devices on the outside wall?
Can I feed over head ? MC or Pipe Spec
Can I feed under, Slab Work?
Which one is easier,faster. Pros` and Con`s?
SIP is and Engineered,pre Built wall with I think foam insulation?
Any Questions or comments Appreciated?
Thanks for your time?
