Nylon
Nylon is the strongest of all ropes in common use. When stretched it has a "memory" for returning to its original length. For this reason it is best for absorbing shock loads, as is the case when lifting or towing. Nylon lasts 4-5 times longer than natural fibers because it has good abrasion resistance and is not damaged by oil or most chemicals. Like manila, nylon has good resistance to ultraviolet deterioration from sunlight, referred to as "U.V. stability".
Polyester
Polyester is very close to nylon in strength when a steady force is applied. However, unlike nylon, polyester stretches very little and therefore cannot absorb shock loads as well...
Polypropylene (Poly)
Because of its light weight, polypropylene is the only rope which floats. For this reason, it is very popular for pool markers and water sports. Poly is affected by sunlight deterioration, more so than any other synthetic or natural fiber rope, but its life can be extended by storing it away from direct sunlight. Poly begins to weaken and melt at 150?F, the lowest melting point of all synthetic ropes. It is not as strong as nylon or polyester, but 2-3 times stronger than manila. ...
Manila
A hard natural fiber, manila is especially resistant to sunlight. It is very popular for public utility construction and repair because it will not melt on contact with hot wires or equipment like synthetics do. It will burn, however, if the temperature is very high or if the rope is in contact with the wires/equipment for an extended period of time. Manila holds knots firmly and stretches very little. ...
Sisal
Sisal, like manila, is a hard natural fiber, but its strength is about 20% less than manila. It too has excellent resistance to sunlight, little stretch, and good knot-holding ability. ... Common uses include gardening, bundling, shipping, and tiedowns where strength is not a critical requirement.
