Six circuit rule
According to table 450.3b, if you have 6 or less ocp means on the secondary of a transformer and the total rating does not exceed what would be allowed for a single ocp. than a main breaker would not be necessary. Is my understanding correct?
for instance: 30a fused switch supplying 10 kva 480-120/240 v transformer
with a small loadcenter containing 6-15a 1pole c/b.
thanks.
Art 450 covers the transformer installation, but you also need to comply with 408.36 if you are feeding a panel.
Actually, 450.3 applies to the rating of the primary device.
You need to look at 240.21(C) for protection of the secondary conductors.
so 6 individually mounted breakers or fused switches would comply?
Not for protection of a panelboard. 408.36 requires overcurrent protection of a panelboard to consist of a single overcurrent device and 408.36(B) requires that when a panelboard is supplied by a transformer that the overcurrent protection device be located on the secondary side of the transformer.
Chris
My opinion, if you complied with 240.21(C) rules on each of the taps and terminated in 6 individual breakers or fused disconnects that were grouped (per 450.3) you would be Code compliant.
(a seperate tap from the transformer to each OCP)
