jdixon
- great falls, montana, usa
I have a water plant that we are upgrading the service on. In 1 alternate proposal we will have 3-12.43kv lines entering the building to disconnects. there are various disconnect to allow power to be transfered from 1 feed to the other in case of problems. It then leaves the building to 4 trnsformers (2-down to 480v, 2-down to 2400v). the 2-480v lines go to the pump building to 2 disconnect. The 2400v lines go back to the switchgear building go through various disconnects to allow power to be trnsfered from 1 feed to the other then go to the pump building to 4 disconnects. At the pump building there are 3 generators (1-480v and 2 combined for 2400v). Would this break the 6 disconnect rule or are generator diconnects not included?
