SG-1
- Ware Shoals, South Carolina
In a six pulse rectifier circuit there is 10A DC load.
How do I calculate the AC Line currents ?
About 8.2A depending on how level the DC current is.In a six pulse rectifier circuit there is 10A DC load.
I'm intrigued, what is a 6 pulse rectifier?
With 100 VAC in you have approximately 6 volts of ripple with out using any capacitors.
If that was addressed to me....Thank you!
what application are you using this for in the context of this thread?
You would two secondaries, one delta, one wye.One could use a delta wye transformer to get a 30 degree phase shift and make a 12 pulse rectifier for less ripple.
Thank you!
