mickeyrench
- edison, n.j.
My company has a service almost like the one in the previous post .We have six transformers being feed from the same pole .The transformers labeled abc and abc. They are feeding the switch gear square d zone111 main breaker with 10 sub breakers with a tie panel and than an exact copy main breaker and the 10 sub breakers. One side main cb is closed with a kirk key in the lock the other side is open and no key in the lock. I don't understand why the 2 sets of transformers being feed from the same pole. What is the benifit of this setup? The only thing i see is if the transformer goes they can switch over to the other side. Can some one tell me why this is done. Also there is a bu generator for service.
