- Windsor, CO NEC: 2023
- Hospital Master Electrician
Say I've got a switch switching 14 wire, and an outlet on 12 wire in a two gang box.
I've been told that if you have #12 in a box, and #14 in a box, that the bonding (<--ah!) conductor for both devices in the box need to be the size of the largest ground, in this case #12.
True, False, Code references?
