Last week wired up an 18,000 BTU mini-split and it only weighed about 300 pounds
Short pounds or long pounds?
... 12,000 BTU/hr is the heat that needs to be removed from water to make a ton of ICE.
Um, no. "12,000 BTU/hour" isn't even a measure of heat; it's a measure of power. The amount of heat that needs to be removed from a ton of water to turn it into ice is closer to 300 kBTU than twelve. And it's
BTU, not
BTU per hour.
About a century and a half ago, in the early days of mechanical refrigeration, icehouse operators asked refrigeration salesmen, "What'll this do for me?" Their response: "This machine will provide the same cooling effect as consuming a ton of ice every day." And the refrigeration ton was born.
But we no longer use icehouses. It would be a good thing if we also quit using refrigeration tons.
(HVACR engineers are among the slowest to adopt new ideas ... if something introduced in 1799 can still be considered "new". Many of them still use Roman Numeral prefixes.)
<rant>
One more example of a good reason to ditch the British system of weights & measures and use metric.
In the metric system, there are only seven base units to learn and just ONE unit of refrigeration capacity, the Watt, (or kilowatt, megawatt, et at.) No confusion and no need for unit conversion.
(there's also ONE unit of efficiency, the dimensionless ε -- no need to fart around with EER, SEER, COP or kW/ton)
https://en.wikipedia.org/wiki/Intern...ystem_of_Units
</rant>
