TheElevatorGuy
- New York, New York
It is my understanding from the code that wire size is based on 125% of the input Amps of the drive. Can someone tell me how to size the fuses feeding it? Thanks in advance.
Yes. That is the name I have always known them to be. Is there a different name you know? Thank you.variable voltage variable frequency?
Variable Voltage Variable Frequency. I checked with the manufacturer and they specify the fuses required. Thank you for your help.Check the mfg instructions, they often will specify a specific fuse type, such as. Type T, and size
What is a VVVF?
