KyleFowler
- Maryville, TN
- Electrician
I have a hypothetical question that I have tried to research an answer to but have been unsuccessful in finding an answer. Below I picked 9kva because it was a small round number for clarity.
What if you had a 9kva three phase transformer with a 480v delta primary and a 208/120v wye secondary, could you pull the full 25 amps its rated for from one phase to neutral? Or could you pull 25 amps from just two of the three phases? I understand none of this is good practice but I'm just talking simple hypotheticals.
I understand that in single phase transformers wired in series with a secondary neutral tap each leg to neutral can only provide half of the wattage. Does the same sort of principle apply to 3 phase except it's only a third? This old ECM web page seems to suggest this without outright saying so although it's hard to tell because some of the links and pictures are broken.
Thanks in advance!
Thanks in advance!
