For sizing breaker for an air handling unit I was using the HP to find FLA and then using FLA*2.5 as stated in 430.52 for inverse time circuit breaker. Is this correct?
Now for A/C equipment with a compressor motor I take the largest motor FLA * 1.75 and add remaining motor FLA to get the breaker size. This was based on section 440.22 Is this correct?
I'm not sure what to do about an air handling unit that also has electric heat. The electric heat load is much larger than the fan motor load. Any hints?
