mstrlucky74
- NJ
So if the equipment is not marked you are to use the 60 degree Column or it could be marked 75 degree then that column would be used. How often is equipment 100a or less not marked or only marked 60 degree? I think just about all breakers are marked 75 degree. Thanks.
