When doing voltage drop calculations should I use the starting current for the load current? Lets say i am sizing wire to run a well pump, which often have long runs associated with them. The running current and startup make a huge difference in the calculation. Or do you just use the sizing guides from the manufacture, seems like they usually give you a lot of info. Thanks
